thread type and size ?
can anyone tell me what type (UNF/UNC etc) of bolt and the size, needed for the floor and leg sheild on a Spree ?
Re: thread type and size ?
The 4 bolts on the floor are 6mm, 1.0mm thread bits as is the one bolt on the inside of the legsheild.
Both are shoulder bolts, to limit pressure on the plastic parts,
Parts fiche says the floor bolt is 6mm x 22mm. The leg sheild bolt is 6 x 16
- Shoulder_Bolt.jpg (14.06 KiB) Viewed 1915 times
so
6mm x 22mm
6mm x 16mm
1mm thread, UNC ?
6mm x 22mm
6mm x 16mm
1mm thread, UNC ?
