Need help, NE50-AF05 BBK tunning.
Rogerio
Post by Rogerio »
After the BBK modification my engine, when hot, sounds like an engine with displaced timing and poor :ndance: :ndance: performance.
Verified carb, adjusted mixture many times, replaced CDI, replaced plug with an BPR8hs but problem remains.
With throtle at 50% (40Km/h) it seems that I've and advanced timing spark or double spark.
Any idea where to look for the problem?
Kind regards.
Exhaust NE50.JPG (75.14 KiB) Viewed 4454 times
Rogerio
Re: Need help, NE50-AF05 BBK tunning.
Post by Rogerio »
Hi Everyone, :b2t:
Need your help, Im decided to try a good Malossi BBK (or any other good manufacturer) on my NE50 engine AF05E (Honda Vision 86-90 in Europe).
The BBK installed gives me a lot of power but a lot of tunning problems (auto-ignition when hot is allways present).
What's the best BBK size for those nice AF05E engines and Malossi/Polini/any other P/N ?
Thanks and Kind regards from Portugal.
Rogerio
Peteyparado
Post by Peteyparado »
What bbk u currently running an carb set up??
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Rogerio
Post by Rogerio »
Peteyparado wrote:What bbk u currently running an carb set up??
BBK from Wemoto/UK and original carb with a Malossi bigger jet.
