another problem
bflath
another problem
Post by bflath »
well now my spree reacts to all throttle amounts just when i get to about 15 or 20 or so it boggs a little. but if i give it full throttle backwards really hard it will continue to go normal without sputtering. does any body know my problem. Thanks
ejames81
Post by ejames81 »
try removing the muffler and air cleaner. also check for vacuum leaks.
-aL-
Post by -aL- »
umm... no... clean the carb maybe... idk what taking your muffler and air cleaner off will accomplish
Ridin' Dirty on one of my 1989 Honda Elite E's
berreta22
Post by berreta22 »
-aL- wrote:umm... no... clean the carb maybe... idk what taking your muffler and air cleaner off will accomplish
The muffler and or air cleaner could be plugged. Removing it will determine that.
-aL-
Post by -aL- »
yeah... he def. didnt say that... shoulda followed it up with a, check to see if theyre plugged or something.. wouldnt want someone riding around w/o a muffler and air cleaner
vonchuk
another problem
Post by vonchuk »
On my 84 I solved that problem by plugging a hole someone cut in my air cleaner cover. You might check to see that the cover is on tight and not leaking. I believe in one of the ancient posts someone had to ducktape the cover onto the air cleaner to solve the same problem.
sprees, ciao, gilera 124, 62 vespa, yamaha 650xs
bflath
Post by bflath »
i just found out today that if i hold the left brake down just enought so the button is not pressed down it will not bog at all
Farfignugin
Post by Farfignugin »
then you might wanna check your ground connections
bflath
Post by bflath »
where all are they at?
vonchuk
Post by vonchuk »
The wires that are screwed to the frame are ground wires. Find those, they will all be the same color. Remove the fastening screw, check that it and the connector are clean. If not, clean with sand paper, wire brush or chemicals and refasten tight. Trace the wires. Make sure all connections are clean and tight.
bflath
Post by bflath »
the only ground wire i can find is the one on i think its the cdi unit. but its fine. does anybody know any other ground connections. also if i unplug the headlight it works fine.
bflath
Post by bflath »
well i was messing around checking all the connections and now my headlight doesnt work at all any one have any ideas?
Gamemedic
Post by Gamemedic »
Check the juction block behind the headlight and make sure all the connectors are pluged in tight.
bflath
Post by bflath »
all connections are tight
