40 mph mostly stock 85 spree
- Goped
Hi all, I have been on here a while and I've been watching people spend hundreds on mods to make a stock spree faster. I wanted to stay cheaper, so I bought a $12 #2250 gates non cogged belt, a size 68 jet, did some minor muffler work, polished the exhaust port, put 1987 spree reeds in it, and polished the entire intake and lightly ported it with a dremel. Also bought a coil and cdi on eBay. I also run only 100% rec 90 fuel. Rec 90 is ethanol free and is also unleaded. I went on a long road and the speedo went right up to 40. Acceleration isn't as good, but top speed is amazing. I'm still experimenting and trying new things.
- The new cdi came with a stock plastic spark plug boot and I switched it with a performance silicon boot.
- image.jpg (183.03 KiB) Viewed 7274 times
- image.jpg (74.79 KiB) Viewed 7274 times
- Here is the belt
- image.jpg (85.58 KiB) Viewed 7274 times
Have 4, 84-86 Sprees
Sprite-85 Honda spree
-87 elite 50 engine
-90 jet
-9 and 10 gram rollers
-Highly ported intake and exhaust
-custom performance muffler
3 original sprees. A red, black and white
-87 elite 50 engine
-90 jet
- patthesoundguy
Re: 40 mph mostly stock 85 spree
Sweet! Get some carbon fiber reed material and cut some new reeds. Pop in a domed piston raise the exhaust port a little and you might get your take off back. I had great luck with the carbon fiber reeds
- Goped
Just recently put in a new domed piston and cylinder in it and got 125 psi in compression out of it and some bottom end. Now I think I blew a crankcase gasket, because it sprays oil from below the exhaust port and has 115 to 110 compression, but still runs fine. I might get the reeds like you mentioned and then shave the head a little bit. How much do those reeds usually cost?
-87 elite 50 engine
-90 jet
-87 elite 50 engine
-90 jet
Quoth The Boss:
Quoth The Boss:
Most times the leak is from the exhaust flange gasket. That thing needs to be quite tight or escaping oil mist is common. Crankcase gasket issue is more serious, and more trouble. Address the gasket, clean the cases with brake cleaner and observe. If it is the crankcase, STOP running it until it's fixed.Now I think I blew a crankcase gasket, because it sprays oil from below the exhaust port and has 115 to 110 compression, but still runs fine.
- patthesoundguy
I got a sheet of of reed material and cut my own reedsBossshelby wrote:Just recently put in a new domed piston and cylinder in it and got 125 psi in compression out of it and some bottom end. Now I think I blew a crankcase gasket, because it sprays oil from below the exhaust port and has 115 to 110 compression, but still runs fine. I might get the reeds like you mentioned and then shave the head a little bit. How much do those reeds usually cost?
- Goped
Ok thanks, I will clean the engine tonight and then ride it to see where it comes from. I also will try to find some reed material to make some new ones for it.
-87 elite 50 engine
-90 jet
-87 elite 50 engine
-90 jet
You're not going to have that compression with a leaking case. As soon as you start to compress it will leak out.
- paulpauly7
or you could not waste and more money on that slow motor and fit a variated af05e or a af16/18 dio motor .Tyese are way way way faster than your spree motor and both have variators they also have lots of aftermarket parts availble
- Goped
I have another build on here. It's called my build:The Spero I was going to put an aero engine in but found an elite for cheaper. I will post more pics on that build tonight.
-87 elite 50 engine
-90 jet
-87 elite 50 engine
-90 jet
