Boring?
xela_p2004
Boring?
Will boring the stock cylinder and adding a bigger honda piston increase performance for a spree?
Boring it to what? Big bore, or just 1st overbore? Sounds kind of "boring" (bad pun intended) to me.
1985 Kawasaki Bayou 185 ATV
1984 Yamaha IT200 enduro
xela_p2004
overbore
Yeah bored to its 1st or second overbore. Basically just getting the stock cylinder and boring it out adding a new bigger honda piston and rings. Doing this will increase displacement I assume. Can this be a simple way to increase performance or just for rebuilding?
xela_p2004
Ok so how big of a piston would I need to notice a difference? I purchased a new piston for my metropolitan it increases my scoot from 49cc to 58cc, I have yet to install it, but the ruckus crowd from totalruckus.com say it makes your scoot run like a two stroke at take off and has enough punch and speed to smoke a stock zuma. They have veypor graphs and data to back up there claims. That is fast for a four stroke. Any how has anyone experimented with buying a bigger piston and boring the stock cylinder, I know Wisco has pistons in all popular scooter sizes. Not sure if its possible just a thought, Iam sure you guys have thought about this before, but is it possible? What is the MM size of the stock piston? If it hasnt been done, maybe I can be the pioneer of this idea.
xela_p2004
xela_p2004
