Metro torque driver CHF50 '14 fit AF16 + 97mm malossi varia
- AIO MotorSportS
- Goped
hi guys I make a research and find the rear torque driver pulley OEM from a Honda metropolitan 2014 fit elite af16.i have to make some more measurements to confirm that.
- CAM00970.jpg (234.37 KiB) Viewed 20350 times
- CAM00969.jpg (246.56 KiB) Viewed 20350 times
Last edited by AIO MotorSportS on Tue Oct 07, 2014 9:30 am, edited 3 times in total.
- AIO MotorSportS
- Goped
Re: CHF50 2014 fit SA50 1994+
more pics
- CAM00975.jpg (141.18 KiB) Viewed 20349 times
- CAM00973.jpg (239.68 KiB) Viewed 20349 times
- CAM00972.jpg (226.68 KiB) Viewed 20349 times
- AIO MotorSportS
- Goped
more pics
- CAM00971.jpg (249.29 KiB) Viewed 20347 times
- CAM00974.jpg (214.54 KiB) Viewed 20347 times
- AIO MotorSportS
- Goped
is 118.5mm O.D.yes I have to try it,and the first thing I know is the pins from SA50 doesn't fit,too big for it,I have to order 3 new ones from CHF50 and I hope fit on my aftermarket half pulley holes
- AIO MotorSportS
- Goped
Re: Torque driver pulley from Metro CHF50 '14 fit SA50 1994+
Just because I like to try
- AIO MotorSportS
- Goped
malossi 97mm variator with metro torque driver
- CAM01095.jpg (158.3 KiB) Viewed 20235 times
- CAM01093.jpg (139.94 KiB) Viewed 20235 times
- CAM01091.jpg (153.8 KiB) Viewed 20235 times
- AIO MotorSportS
- Goped
more pics
- CAM01109.jpg (120.81 KiB) Viewed 20235 times
- CAM01106.jpg (118.79 KiB) Viewed 20235 times
- CAM01103.jpg (164.17 KiB) Viewed 20235 times
- AIO MotorSportS
- Goped
Re: Metro torque driver CHF50 '14 fit AF16 + 97mm malossi va
to fit the clutch bell cover
- CAM01084.jpg (182.62 KiB) Viewed 20233 times
- CAM01083.jpg (177.48 KiB) Viewed 20233 times
Good work, the malossi for ruckus is the same size as the polini for ruckus. There was a seller on ebay that had some malossi for ruckus for sale for 60$ a little while back. Full kit too.
- AIO MotorSportS
- Goped
may this help dirtyE
AIO MotorSportS wrote:more pics
This is what I wanted to see!
Is it the same on zx?
Will the 18070cc clutch work on the met rear pulley? Maybe the met and zx are the same?
I have tranny envy! You got what I want!!!!
98 Elite
4 strokes are for cars
I can't see any threads on your crankshaft??? Maybe it's just the angle and light playing tricks???
- AIO MotorSportS
- Goped
