Anyone rain proof a pod filter?
devenex
Post by devenex »
Winter is fast approaching here in the PNW and I'm hoping to make my swapped spree rideable in wet weather. I believe the stock af05 airbox will not fit under the spree plastics, so this leaves me searching for ways to water shield the pod filter I currently have installed.
Has anyone successfully done this? Or is there some aftermarket airbox that will fit the stock carb and squeeze in the spree's body panels?
1986 Spree w/ '87 SE50 motor
808EERPS48
Re: Anyone rain proof a pod filter?
Post by 808EERPS48 »
im pretty sure they have a rear tire guard for the spree on ebay the last time i checked.. or if you wan to do some fabrication you can make a plate or shield out of sheet metal that extends from thebore and past the shock couldnt find the pix i had on my phone bu this is sort of similar to what im trying to tell you
honda dio.jpg (12.67 KiB) Viewed 13901 times
84 Spree dio ready
Youtube me: Go RYAN Pro
True 72cc
70+/F/72
Reppin it for the 2+ class
Eastsydah Rydah Productions
#Handodat
cruzingratiot
Post by cruzingratiot »
outerwears FAQ
http://www.outerwearsracing.com/page.asp?region=9
Will adding an Outerwears Pre-Filter stop water ingestion? - 11/03/2004
The Outerwears Pre-filter is an excellent solution to prevent water from entering into the engine due to puddles or heavy rainstorms. An Outerwears Pre-Filter is designed to be water repellent and will reduce the risk of water entering through an air intake system. Although our Pre-Filters are proven to be extremely effective in repelling water, please keep in mind they are not water proof. If submerged, your intake can hold or pass water. Outerwears Pre-filters are an excellent solution to prevent water from entering into the engine
Outerwears Pre-Filters are designed to repel water against heavy rainstorms and road puddles
main sight
Donate Life
http://www.donatelife.net/
Thank You
Mystic
Post by Mystic »
I took a blue plastic cup and cut it to length and used a self tapping screw to attach it to the pod and cut purge holes in the bottom :D they sell covers for the pods I think. I know they sell the same kind with transparent covers on them already
ped
Post by ped »
graphite9 wrote:I have these, polinis with snap ok covers. They are going to be as close as you get. An outerwear is also an awesome suggestions.
hi Devinex. I picked up a polini blue filter from graphite. Looks very good for protection against rain.
:thumbwink:
devenex
Post by devenex »
Thanks for all the ideas guys!
I PM'd G9 about those sweet looking polini filters.
