NEED HELP
reckless504
NEED HELP
Post by reckless504 »
yesterday i was riding my spree behind my friend and his moped and its was at night and he stoped and i rear ended him going like 20 mph. when i rode home it wouldnt go faster then 15mph halfway there then it started picking up. so today i started tinkering and it was bogging. i adjusted the idle screw and changed the spark plug and it still wont go faster then 26-27mph if it even gets to that. what can i do to get back my speed???!!! help!!!!
1986 Honda Spree w/ pulley mod clocked in at 37mph hauling 175 lbs. Don't believe me? lets race!
vonchuk
Need Help
Post by vonchuk »
Have you checked front and rear wheels to see that thay spin freely? No brake drag or bent rim rubbing. Check for loose drive belt. slipping clutch.
sprees, ciao, gilera 124, 62 vespa, yamaha 650xs
reckless504
i know the wheels spin freely, and if the belt was loose it would slip and you would feel it right? is there anything else it could be? in my past experience i had a topping out issue and changed the voltage reg and that solved it but... i dont know
vonchuk
Post by vonchuk »
You have to think of things that could happen from a sudden violent stop. Or tip over. Such should not effect anything internal to the engine. It could knock dirt loose in the fuel tank that could suddenly plug the filter at the outlet or plug one of the small opennings in the carb. Usually jared loose wires would keep it from starting. Loose hoses result in a visible leak unless a vacuum tube from carb to fuel pump.
deathwish
Post by deathwish »
Is the Spark plug cap on the plug tight
Wanna kno how to keep an idiot busy for hours look below
Wanna kno how to keep an idiot busy for hours look above
reckless504
yes the plug is tight
MySpree
Post by MySpree »
cheack ur commpression, sometimes if u crash like that and you have pay in the crank the piston rings wiht go bad. were is garden city? near troy?
reckless504
i checked compression 145 lbs. yea it has a brand new piston and brand new rings in it. anyway i tinkered with the carberator again and got it going 31 so yea but i live in garden city by the gc police station.
berreta22
Post by berreta22 »
holy s***..145psi?
speedyspree
Post by speedyspree »
kool u got it goin 31 or did i
85 spree honda cb 125 and 2 pocket bikes(for sale)
reckless504
i got it runnin and yea i have no idea how its getting that much psi in the compression test i guess its the new piston and rings and gaskets idk
