Fat Tire Kit
Fat Tire Kit
Has anyone attempted a Stretch and Fat Tire Kit on Spree without having to swap out the original motor ??? If so I need Info PLEASE thanks, D.
- 5t8br0j4shpm.jpg (8.76 KiB) Viewed 5173 times
Re: Fat Tire Kit
A strech is as easy at relocating the shock mount and extending the motor mount. Graphite9 sels a kit if you don't want to do it your self. As for the fat tire I don't think there is much you can do with the spree motor as I think the spree has a different rear rim than the rest but I could be wrong. If I'm wrong a met rim would be a start or a kymco hub and some case and exhaust mods you could go bigger. But someone with more spree experience will have to confirm.
Re: Fat Tire Kit
I really appreciate the help ill check it out thanks, D.
Re: Fat Tire Kit
Are the spree rear axle splines different from af05/16 splines? I was pretty sure but want to be clear.graphite9 wrote:There are no hubs or wider wheels that im aware of.
Re: Fat Tire Kit
thanks for the help really appreciate all the help I can get still researching
Re: Fat Tire Kit
Hi TF. the 94 and up elite shaft will not fit the spree wheel. and vice versa. hope this helps.
- 20141028_222011[1].jpg (178.2 KiB) Viewed 5062 times
Re: Fat Tire Kit
TF, is looking for this lookgraphite9 wrote:ped wrote:Hi TF. the 94 and up elite shaft will not fit the spree wheel. and vice versa. hope this helps.
whoa ped. This is way to G rated. Are you feeling ok?
Just joking topfueled.
