my offset shock mod
ped
my offset shock mod
Post by ped »
Hi forum.
my stock shock it's just not good enough. I found this used adjustable shock and did a offset mod to clear the tire. Take a look.
I think the stock shock is 260mm this one is 280mm tall.
ped
Re: my offset shock mod
Post by ped »
:smile: the lower bracket came from my old spree shock.
the spree shocked is spring loaded. I had to use two needle nose vice grips to hold the load.
so that I can take a little bracket off.
ped
Post by ped »
:urban:
ped
Post by ped »
:nerd: Perfect fit between tire and airbox.
LMH
Post by LMH »
Nice job ped!
ped
Post by ped »
:urban:VERY Important to keep shock oil cool. I had to keep a wet rag on it, and weld a little at a time. so that the oil inside would not get heated and damage the seals.
ped
Post by ped »
thanks Mr love. The ride is much smoother. And adjustable. a lot better than stock. :peace:
it would be easier to just buy one from graphite, scooter swap shop. But I like making custom stuff. :smile:
AIO MotorSportS
Post by AIO MotorSportS »
nice job :2thumbs:
paulpauly7
Post by paulpauly7 »
i did this to my rear shock but i cut off the whole u shaped bracket and moved it over 5mm then welded it back on .
S4Patrick
Post by S4Patrick »
Looks solid, awesome work Ped. Love the water-cooled shock idea too.
'92 Super Dio ZX - AF18 Corsa
patthesoundguy
Post by patthesoundguy »
Great use of the metal melter thingy and your imagination :-) looks perfecto. I'll be on the hunt for a shock like that for my dio spree
ped
Post by ped »
Hi forum. Thanks for the great feedback. :thumbwink:
I like doing these kinds of mods. but they do take time and work to make.
Like I said before it would be easier to have graphite from scooter swap shop just order one.
and its a lot safer if you can't weld.
like me lol.
patthesoundguy
Glad I have a welder too, it helps when you have the inspiration and you can just grab the torch, clip the lead on and weld something. In my new workshop I have the welder right by the door under the bench where the vise is so I can mod and fix at a moments notice. The torch reaches in the floor with no trouble to weld on frames and such without relocation of the box. I also picked up a DC inverter buzz box for real cheap on sale to set up a scratch start tig rig when I get all of the bits together from eBay. :-D
patthesoundguy
I'm thinking of getting a tig welder that also doubles as a plasma cutter. They aren't too bad from eBay. That's not going to happen anytime soon though. The cheap tubing benders go on sale all the time at princess auto for about 100$ to 120$ I want one. Its funnyhow we have thousands in tools to fix machines like sscooters lol
phatkix
Post by phatkix »
Cool mod.
patthesoundguy wrote:I'm thinking of getting a tig welder that also doubles as a plasma cutter. They aren't too bad from eBay. That's not going to happen anytime soon though. The cheap tubing benders go on sale all the time at princess auto for about 100$ to 120$ I want one. Its funnyhow we have thousands in tools to fix machines like sscooters lol
That Princess Auto tubing bender is pretty crappy. I wouldn't recommend it :imo:
elite_dub wrote:As for you phatkix you speak as you please, I know you can't play with the big boys.
