Malossi crank ID
Malossi crank ID
I bought a new Malossi crank for my 01 elite and I'm unsure which engine it is for. It was labeled as a dio or similar crank and I'm guessing that it's for a af18. I hope someone can identify which engine it is for by looking at my pic. If it is for the af18 what do I need to run it on my af16 setup? I noticed that my outer pully does not fit very snug on the splines, it wiggles quite a bit. Thanks for your help!
78 Honda Hobbit Athena
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
Re: Malossi crank ID
What was the part number, if you can measure the diameter it works for id also.
No part number, it came packaged with other stuff and it was not in the styro box which would have the sticker on. 20mm where the bearings sit and 14mm where the boss rides and 48ish from the shoulder where it is 14mm to the start of the threads on end. The stock is the same but a little different at the splines.
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
Thanks LMH and G9! It does say malossi in the con. I'm rebuilding my elite and noticed the sloppy drive face and thought I might need different trans parts to match.
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
Ive got the same issue here. Gonna start searching for buried treasures here. G9, ill PM you about this, but do the aluminum drive faces you have fit to the malossi crankshaft properly?
98 Elite
4 strokes are for cars
Post a picture of the crank and splines. There are 2 cranks. Small and big shafts crank for dio.
- cruzingratiot
I put a second washer with a bigger id than the splines and length past the splines
no problems with about 4,000 miles on build
even needed washer with alloy drive face
Paul
Paul
Donate Life
http://www.donatelife.net/
Thank You
Thank You
Ill post up pics tomorrow. Its late. Im only gonna be kicking this pig over.
98 Elite
