Hello all I have Question I'm going to buy tires for my Spree and was wondering if anyone has put a little wider than stock tire on the rear ? if so what brand and size was used any help is Appreciated thanks D
Tires
streetglide07
Re: Tires
Just came across your post about tire size. Hope this info helps you decide. I just installed 2.75 X 10 Kenda tires with no rubbing or clearance issues anywhere front or back. I dont see any bigger tire fitting without modifications to the rear fender/airbox. Only $30 each on ebay
Kevinstonge
