Oil pump plug
Posted: Sun Jan 25, 2015 4:45 pm
by gza710
I installed a oil pump plug on my dio. After a few blocks it popped off. Do I need to put permartex or something. All I did was tapped it all the way down. Please advise. I'm noobing. Thanks
Re: Oil pump plug
Posted: Sun Jan 25, 2015 5:03 pm
by paulpauly7
use the bolt hole for the original pump and bolt a little plate over it to stop it coming out .Also a little hondabond around the plug befor install helps stop air leaks
Re: Oil pump plug
Posted: Sun Jan 25, 2015 5:04 pm
by curtis966
You still need to brace it just like the oil pump. I use the original hardware and a piece of steel to hold it in place. A bolt into the plug the bolt to the left and the steel as a brace between the 2.
Re: Oil pump plug
Posted: Sun Jan 25, 2015 5:05 pm
by curtis966
paulpauly7 wrote:use the bolt hole for the original pump and bolt a little plate over it to stop it coming out .Also a little hondabond around the plug befor install helps stop air leaks
+1 on the sealer as well!
Re: Oil pump plug
Posted: Sun Jan 25, 2015 8:10 pm
by gza710
d*** I'm such a noob. Thanks all
Re: Oil pump plug
Posted: Mon Mar 02, 2015 6:23 pm
by johnny248
Mine is recessed when I push it all the way in. I didn't use ant sealer, just a little oil on the o-ring. We will see how that works. I also made a little plate and put a spacer between the plug and plate to keep some preload on the plug. Here...scroll down.
viewtopic.php?f=16&t=30606&start=15
