07 Honda Elite 80 Valve Cover Seeping
joew8638
Post by joew8638 »
Im doing a valve adjustment as part of winter maintenance on my 07 Honda Elite 80 with 7,000 miles on it. When I go to do my valve adjustment ( I did the last one about 2,000 miles ago ) I clean off the valve cover and reuse the valve cover gasket which seems fine, but 2,000 miles later I have this oil seepage on it. Do you guys have that too? Common? Should I replace the gasket or put some sort of sealer on it?
Thanks,
Joe
[img]CH80%20Valve%20Cover.JPG[/img]
CH80 Valve Cover.JPG (82.8 KiB) Viewed 2182 times
Re: 07 Honda Elite 80 Valve Cover Seeping
Gaskets are cheap. Replace. You'll sleep better.
