Bore stock cylinder to 48mm??
Searched and couldn't find anything...
Is it possible to bore the stock cylinder from 41mm to 48mm? I know Taz sells a kit, but can I just buy the piston and then have it bored?
1987 Honda Spree - Black - Purchased 3/9/2015
48mm Big Bore Kit
Complete engine rebuild - All new seals, bearings, piston, cylinder, and gaskets
48mm Big Bore Kit
- cruzingratiot
Re: Bore stock cylinder to 48mm??
if you can bore the stock cylinder ?
take into consideration price of everything
Piston$$
cylinder boring & honning $$
Gaskets $$
your time finding someone to do the work
dropping it off picking it up and than waiting for it to be done and gas $$
or buy it shipped to your door and done $$
Piston$$
Gaskets $$
Donate Life
http://www.donatelife.net/
Thank You
Thank You
Just ordered the kit
Thanks for the advice!
48mm Big Bore Kit
48mm Big Bore Kit
- paulpauly7
"dude swap in a dio"
I would not suggest boring a 41mm cylinder to 48mm. the ports would surely change timing drastically as the farther out you go, the port ceilings drop.
98 Elite
4 strokes are for cars
- patthesoundguy
We have seen what happens when you bore a stock spree bore out to 48mm. It wasn't pretty
- patthesoundguy
I really liked my big bore setup on my spree. It was pretty fun and if you want more guts on the cheap its a good way to get it. Its way cheaper to get the whole kit. http://m.ebay.com/itm/371080961158?nav=SEARCH
patthesoundguy wrote:I really liked my big bore setup on my spree. It was pretty fun and if you want more guts on the cheap its a good way to get it. Its way cheaper to get the whole kit. http://m.ebay.com/itm/371080961158?nav=SEARCH
That's the kit I bought
Just waiting to put it on now
48mm Big Bore Kit
48mm Big Bore Kit
kirt70camaro
Keep us posted how well it works. A lot of people say it will seize up because the quality is poor. So give us updates every so often please.
Well that's not what I want to hear....kirt70camaro wrote:Keep us posted how well it works. A lot of people say it will seize up because the quality is poor. So give us updates every so often please.
It appears to be good quality so it should be interesting.
I'm gonna create a build thread so keep an eye there.
48mm Big Bore Kit
48mm Big Bore Kit
- paulpauly7
make sure you chamfer the ports befor install .
- patthesoundguy
Great tip pauly! I always do that to my new cylinders. Even if the whole thing is supposed to be bolt and go, it likely needs the proper port chamfers done before you install. It sure helps the durability. Many of the big bore spree kits have been very durable. The cylinder kits from Taz is real and not junk, as long as you follow proper break-in procedure everything should be great.paulpauly7 wrote:make sure you chamfer the ports befor install .
Glad to hear it!
48mm Big Bore Kit
48mm Big Bore Kit
