Electric Starter
BluPhire
Electric Starter
Post by BluPhire »
Do you or have you hade problems with your electric starter motor?
I try to fix things with a hammer and wrench!
Jerry
Post by Jerry »
Any mechanical part and especially an electro-mechanical part will wear out. It is not at all hard to replace the brushes and lube the surfaces to get another ten years out of them.
Scoot safely
vette76
Post by vette76 »
i am going to have to disagree about how easy it is to change the brushes.lol
BluPhire
Post by BluPhire »
Where can I get new brushes? I plan on ripping my starter motor out today and check everything out.
vette76
Post by vette76 »
u did try to see if it works before u pull it out right? if i were you i would not take the actual starter apart.
Jerry
Post by Jerry »
C'mon Vette, it's not that scary. You can get brushes from the dealer, but it's a lot cheaper to go to the hardware, find similar brushes and gring them down to fit. I've done it a number of times.
Try the starter when it's removed from the engine before disassembly. If it doesn't work, what could it hurt to try to reapir it?
Scoot safely
vette76
Post by vette76 »
ive just had bad experiances i guess. its the kind of thing that takes patiance.
BluPhire
Post by BluPhire »
I wish I had checked if it worked when it was out before ripping it apart. The brushes were a pain the the rear end though. When I finally got it put all back together, and hooked up the battery starter/charger to my battery and tried to start her, the electric motor began to smoke worse than the inside of Snoop Dogg's van on 420. lol. Now the motor won't even turn at all. Oh well, I never used it anyway.
vette76
Post by vette76 »
same happened to mine. check ebay, thats where i got mine. i sent one out to be re-built, but they could not find the parts to re-build it.
