Exhaust
Exhaust
I am looking for a better exhaust then my PG short anybody can recommend any? Also looking for an everyday exhaust quieter then what I have but won't cut the performance... any help will be awesome.. thanks
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Stage 6 intake manifold
Sparrow Exhaust
Polini Ruckus Variator
Malossi Fly Clutch w/ blue
1500 contra
Lightened mag
7.4-1 gears
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
Re: Exhaust
The Technigas pipe I have is pretty quiet. Some will say that it doesn't have the high rpm performance as some other pipes do, but it seemed to work fine on the 72cc Taiwan kit I had. Don't know if that helps. I have some videos posted on my build page if you want to listen.
viewtopic.php?f=16&t=30606
~UNDER CONSTRUCTiON~
Re: Exhaust
sounds pretty quiet... but if it doesnt handle the rpms then it will lose performance .... Nice pipe though who sells that
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
Re: Exhaust
I'm guessing there is always going to be some compromise. I don't think there is such thing as a super high performance pipe that is going to be really quiet. Larger silencer means more restriction :/
Re: Exhaust
graphite9 wrote:I have one technigas for dio in stock right now. $180 shipped, brand new
It might not be the baddest screamer that is out there, but it provided a really good power band on my bike and wasn't crazy loud.
Re: Exhaust
Yeah! I didn't realize that that center stand bumper on it is something that doesn't exist on all of these other pipes. The clear coat burnt off of mine (I'm assuming it burnt off) and I put a couple coats of 2500┬░ paint on it and I think it looks real nice. Not sure it the other pipes do the same thing. Every pipe I've had has always been nickle plated (2T MX and quads)
Re: Exhaust
do you have a picture of it? whats the sweet spot of this exhaust? is it better then my pg short?graphite9 wrote:It's a good pipe. and it comes with a center stand rubber stopper. quality is great.
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
Re: Exhaust
you can go with a pg stainless or a newer malossi wildlion pipe, or if you can find a rare ddx airbox .
Re: Exhaust
Where do you get a yasuni c16 exhaust from? So you say this is better then a scorpion exhaust?
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
Re: Exhaust
I just got a scorpion exhaust any tips on tuning?
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
- Downsouthdio
Re: Exhaust
Light weights,when i was running scorp i was using 3 gram weights,with the sparrow now,6 gram weights
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Re: Exhaust
My best pipe is a polini smokeless gun comepletely rebuildable aluminum pipe, it has that 2 stroke ting sound....
