Replacement Key
wherman1
Replacement Key
Post by wherman1 »
We lost the key for our 1986 Honda Spree. I have the Vin number but am not sure how to go about getting a new key. Can anyone help??
Trackerrrr
Re: Replacement Key
Post by Trackerrrr »
eBay has the key blanks, or you can try your local locksmith and see if they have them.
martynkim
Re: Replacement Key
Post by martynkim »
Remove the lock take to a Honda motorcycle shop and they can cut a key from the code on the lock. $10 at my local shop.
wherman1
Re: Replacement Key
Post by wherman1 »
Thanks for the help. Now....how do you remove the lock?
cruzingratiot
Re: Replacement Key
Post by cruzingratiot »
viewtopic.php?f=11&t=37 <link to manual
download the shop manual
Donate Life
http://www.donatelife.net/
Thank You
martynkim
Re: Replacement Key
Post by martynkim »
Remove leg shield, the rest is self explanatory. If you can't do it you have no business owning a Spree.
otto-man
Re: Replacement Key
Post by otto-man »
You need a 8mm and a 10mm socket. Remove rear rack (4 nuts).Remove plastic side covers (1 nut, 1 bolt, and 2 plastic clips in back).Remove the 4 bolts that hold the floor panel on. Then 1 bolt on the leg shield and carefully pull up the bottom of leg shield and disconnect the wires. Wires are colorful so reassembly is a no-brainer. You will see the switch has 1 bolt and 1 nut holding it to the frame. Disconnect the wires and you are on your way!! Good answer martynkim:)
otto-man
Re: Replacement Key
Post by otto-man »
Or......If you are coming to central Minnesota, stop by for a cold one and I'll do it for you :smile:
