Rattling Noise
Rattling Noise
So got my spree running and I noticed there's a rattling noise and it sounds like it's coming from inside the belt drive cover has anyone had this problem ? It doesn't affect anything it's just annoying any help is appreciated thanks, D.
Re: Rattling Noise
Open the cover, Your crank nut may be loose. This is the one toward the front of the engine if you are unfamiliar with these bikes.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
Re: Rattling Noise
Every thing was tight would a bad belt cause it ?
Re: Rattling Noise
didnt believe the answers you got on the other forum i see lol. Its funny because the answer remained the same... Pull the cover and look...
92 Yamaha Jog CY50
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
16 Kawasaki Versys 650
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
Re: Rattling Noise
Yes, a bad belt, especially one with some bits starting to unravel will cause much unwanted rattle.
- patthesoundguy
Re: Rattling Noise
I agree on this. Having seen my share of trashed belts on various machinery. Another source of a rattle could also piston slap. Or a clutch issue.motormike wrote:Yes, a bad belt, especially one with some bits starting to unravel will cause much unwanted rattle.
