Bad to worse, now it won't start
Posted: Fri Sep 29, 2006 1:51 am
OK, so the sick little scooter saga continues.
Down from the high of my previous post, now my Spree won't start.
Here's the scoop:
It ran fairly well, but was a tad hard to start sometimes, and it seemed like it was idleing slow.
I tried to adjust idle and air screws as per technical manual, and didn't have much luck. In fact, I made it worse, so that it would start, and idle fine, but as soon as I gave her gas, she would bog and die.
So, the answer to everything in these forums seems to be "clean the carb". I followed the carb-cleaning instructions in the technical documents step by step, ensuring that a good clean squirt of carb cleaner went through (and came out of) every hole. I made sure I could see light through the main jet.
Reassembled the carb, set the air and idle screws as per instructions. I know that my petcock is stuck open, so no need to apply vacuum and fill the bowl. I did remove the bowl drain, to make sure that gas was flowing into the carb. It was, and I replaced the drain.
Now it doesn't start. I pulled the spark plug, and checked for a strong spark. The plug was not wet, so no flooding. The spark was strong. While the plug was out, I used a compression tester and tested the compression in my new engine. 130psi, so it's high and needs decarbonizing, but I would prefer to save that for a maintenance job once the engine is running. But obviously no need to think about rings or piston damage with compression like that.
Airbox is tight, filter is installed, I don't have screw for the middle, but that's covered with tape for now.
I'm stuck here: everything seems right, but it just won't start. I don't see how a carb cleaning can make it go from starting to not starting.
Any thoughts?
Thanks guys!
Here's the scoop:
Any thoughts?
Thanks guys!
