72cc Polini Corsa / Malossi MHR Build
hi forum. I looking to do a FAST 72cc. the only one I can think of is the polini / malossi setup.
- 20150413_180952.jpg (197.69 KiB) Viewed 8373 times
Re: Polini Corsa / Malossi MHR Build
- 20150413_183606.jpg (220.31 KiB) Viewed 8373 times
- 20150413_183702.jpg (220.14 KiB) Viewed 8373 times
- Downsouthdio
I love mine..just wonder if stock stroke corsa is faster than mini stroke..good luck!
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
I'm not 100% sure which ones faster? but the stock stroke is pretty fast. it loves to rev.Downsouthdio wrote:I love mine..just wonder if stock stroke corsa is faster than mini stroke..good luck!
Re: 72cc Polini Corsa / Malossi MHR Build
Im hoping for some pretty crazy low end power out of my MHR build. With the 8.44s I should still be able to see 65 easy and still have a mean 0-50mph which is my main goal. More about the off the line power then top speed for me though. And I'm pretty sure the stock stroke full counter malossi is the best crank for these motors.
- Mini_Stroker305
- Goped
Nice parts my man good luck with the build
96 Yamaha Jog Next Zone CY50
72cc Polini Evo 2
Ruima 41.4 Teflon ministroke
Yasuni C16
24mm Polini pwk
Malossi 8:1 Primary Gears
Malossi VL14 Reeds
Polini 360 Mani
Jaingwayne transmission
Michelin S1 tires 90/90/10
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
- Downsouthdio
Yea ive heard.. Im talking what would give more top speeds
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Hi DSD. I have to correct that sentence, to do a fast 72cc. LolDownsouthdio wrote:Yea ive heard.. Im talking what would give more top speeds
I only know a little bit to make them go fast.
I would have the head work done. Cut the flywheel, DDX variator, stage 6 bell, lots of tuning.
- Xxbeejay45xx
Love the MHR crank and corsa! High reving combo that can take a beating.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
