Anybody that's using the stage6 fully adjustable clutch how do you have it set? And what set up are you running?
I just set mine with white springs at about 3/4s tight and 6 of 9 weights installed. Just because not because I know lol.
Stage6 Cluch Settings
Re: Stage6 Cluch Settings
It took me 2 weeks to figure out that it would not work on my 112mm larger scoots, play with it and then post when it snaps your neck on take off
