Spree BBK Oil mix/clutch
scootacris
Post by scootacris »
Do I have to premix my gas and oil with the spree 48mm bbk w/21mm carb, or can I still use the stock oil pump? If I premix what ratio?
Also, will my stock clutch/gear step-up be alright with this bbk?
Thanks for help :newb:
Re: Spree BBK Oil mix/clutch
Post by swimmingfree »
gas oil mix is 32 to 1 you shood run 64 to 1 ...
scootacris
swimmingfree wrote:gas oil mix is 32 to 1 you shood run 64 to 1 ...
Alright, thanks for the info :smile:
patthesoundguy
Post by patthesoundguy »
The stock clutch works perfectly with the big bore set up. And if you don't change the gear ratio at all the stock clutch springs are also fine. You won't go all that much faster with that setup with out changing the gear ratio but it will have great guts.
scootacris
patthesoundguy wrote:The stock clutch works perfectly with the big bore set up. And if you don't change the gear ratio at all the stock clutch springs are also fine. You won't go all that much faster with that setup with out changing the gear ratio but it will have great guts.
Appreciate the feedback! I've read a bit about the gears on the wiki and it says an aftermarket set is available for the spree but I can't find it? I'm not lookin to go much over 35mph.
