Can I add a Kick Start to a 1985 Aero?
mrgoodness
I know you can add a kick start to the sprees that dont come with a kickstart, by drilling a hole and adding the kickstart mechanism. Can I do that to an 85 aero?
Re: Can I add a Kick Start to a 1985 Aero?
I'm not sure you can drill a hole and add the parts nor do I think it would be cost effective. But you can get he cover from another af05e motor from later aeros or elites and it bolts right on.
mrgoodness
Ok thanks for the info, that makes sense.
I forgot you will also need a drive face from a kicker model as well because your drive face is smooth and doesn't have the teeth required for the kicker to engage.mrgoodness wrote:Ok thanks for the info, that makes sense.
Yes you can convert an 86/87 trans cover with front face.
