Page 1 of 2
Posted: Wed May 20, 2015 1:23 pm
by 1man8scoots
Re: stage 6 cdi
Posted: Wed May 20, 2015 9:56 pm
by curtis966
How do you rate the malossi over the stock cdi? what are the benefits?
Re: stage 6 cdi
Posted: Wed May 20, 2015 10:09 pm
by 1man8scoots
Better start up, cleaner revs at high rpms, and cheaper than buying an oem also. Only one map tho and the stage 6 has 2
Re: stage 6 cdi
Posted: Wed May 20, 2015 10:27 pm
by curtis966
Cool. Are there any differences in the 2 malossi cdis? Other then the rev limit switch on the one.
Re: stage 6 cdi
Posted: Thu May 21, 2015 12:10 am
by 1man8scoots
No difference I can tell besides the rev limiter switch.
Re: stage 6 cdi
Posted: Thu May 21, 2015 9:05 am
by DirtyE
Whitey and I ran the stock cdi and the malossi cdi on his stroker to see if it would alter his temps. Not difference, so we put a timing light on it and revved til about 8k with both. We saw essentially NO difference. We didnt get into higher revs though.
Re: stage 6 cdi
Posted: Thu May 21, 2015 9:14 am
by 1man8scoots
When they're scoped there's a world of difference. Ive been told I should say as Ive yet to try. Your eye can't see the path they both take as they both curve from the get go. A timing light is good for checking base and irregular revs.
Re: stage 6 cdi
Posted: Thu May 21, 2015 2:01 pm
by DirtyE
Hmm. Seems like we would've seen some movement. Ill take your word for it though. ;)
Re: stage 6 cdi
Posted: Thu May 21, 2015 2:11 pm
by curtis966
Good info. I've been looking at the malossi cdi so I will wait to hear something on the stage6 before I pull the trigger. G9 where you at??? Have you tested one yet?
Re: stage 6 cdi
Posted: Thu May 21, 2015 2:16 pm
by 1man8scoots
He hasn't yet I asked. I'm hoping someone has used it and knows the low down. I'm interested in the dual maps, maybe ones for race and ones more, uh retarded.
Re: stage 6 cdi
Posted: Thu May 21, 2015 2:38 pm
by curtis966
What would you consider the malossi map as? Race or just a better then stock option?
Re: stage 6 cdi
Posted: Thu May 21, 2015 2:43 pm
by 1man8scoots
Just better than stock, but not much. Way better than the China cdis that have bad initial timing. Josh/Aeromyst from another forum or 2 did a write up on them.
The biggest thing is always going to be how far it retards at high rpms. Further retarded the hotter the exhaust gases get so the quicker they flow.
Re: stage 6 cdi
Posted: Thu May 21, 2015 9:10 pm
by DirtyE
For some reason I was thinking the "aftermarket" cdi's retarded, advanced, then retard again at higher rpm to keep temps down, but maybe that is head temps?
Re: stage 6 cdi
Posted: Sat May 23, 2015 10:32 pm
by TinyElvis
interesting!
Re: stage 6 cdi
Posted: Sat May 30, 2015 9:14 pm
by TinyElvis
Where are you fellas getting these CDI's?
