Flash 9: Sanity Restored
Fire-breathing, 75-MPH Flash 7 proved just a little TOO hot for civilized Country-Club riding with Ms. Wheel-Person astride. No problem baby, I'll just score a nice wholesome stock engine and tone things down a tad. This too she rejected as just a little too gutless. The porridge is too hot, then too cold... What we need is Just Right.
She still wanted the quiet, "sleeper" look but a bit more Torque on take-off. One pleasant Saturday garage session for Wheelman later and here it is:
Re: Flash 9: Sanity Restored
After removing Flash 8 from the 2001 crankcase supplied by a Forumista with well-deserved respect, I ran into some snags. I installed the piston as usual, but as I dropped the Polini cylinder into place, I couldn't get the headbolts lined up properly to thread. Thinking the gasket was cut wrong, I "ovaled" the holes, but still no-go. Finally (and Lord knows I really hate doing things twice...) I removed the piston again and Dry-Fitted the cylinder to surmise that the larger 47 mm bore's skirts were fouling the crankcase.
That'swhy it wouldn't line up. Removing the cylinder yet again, I could see how the thing fouled the curve around the transfer port:
The contact pushed the whole cylinder to the left, and far enough so that the bolts couldn't line up. Not wishing to split the cases to carve on them, I just resolved the issue the same way the previous owner appears to have done:
With the cylinder lying flat and flush on the crankcases, (and the headbolts threading in without issues...) It was time to re-do the cylinder installation from the Piston on up.
curtis966
Post by curtis966 »
That's odd. I don't think I've ever seen or heard of a cylinder under 50mm not being bolt on especially an Italian.
Cylinder preparation included a generous slathering of Motul Synthetic:
Yeah, this is a first for me too. I can't help wondering if the crankcase is atypical somehow...
So what're we gaining here? A 6mm increase in diameter doesn't sound like much, but it's actually a 45% displacement increase. It's starkly apparent here:
On top of that is the Polini Porting Wizardry, albeit tuned for low-end torque here. The piston appeared to go a hair below the transfer ports and the exhaust port at BDC,
and left a little squish at TDC:
It's an Iron Contesta, packed in Gin-You-Whine Polini carton wrapped witta-da Polini tape. It really doesn't seem like a knock-off, and I've bought at least 2 before. My suspicion is that my 2001 "Honda" crankcase might have been part Sym... The fact that the stock Honda cylinder needed to be carved too is a Clue.
A word on Piston installation:
Seems easy enough, but I recommend you keep a pristine set of quality needle-nose pliers swaddled in oil-soaked cheesecloth for this occasion. Do NOT use the ones you use to pull out errant nose hairs.
Read the caption. Read it again. Be gentle with these spring clips. Don't stretch them beyond their elasticity. Dozens of posts over the years confirming the disastrous consequences of a circlip popping out. On the Polini-style clips, the "legs" must point up or down with respect to the piston. That thing is hammering over 100 times a second, so a clip on its side just might have the momentum to work loose.
Another potential Snag with this build:
Good thing I've got 50% AvGas in the tank. Is there a risk if I run Premium - or rather Ms. Wheelperson does?
1man8scoots
Post by 1man8scoots »
I got the contessa from you, and he from me.
It sounds like the deck of the engine is lower some how. This for certain I've never removed the cylinder and the guy I got it from really didn't seem too mechanically or intellectually inclined.
So odd. I wonder how many other blocks are like it. In order for it to leave the factory they would have had to cut it at the factory. When they tried to bolt it down from the factory someone had to say, "hey boss it don't fit?". Maybe ask honda about this oddity? Your 01 block I received did you have to shave any skirts?
Everything I bolted onto that case was unshaved except the Fabrizi, which needed the piston "corners" knocked down. That block saw a Nikasil 78, Corsa, Malossi Iron and MHR - none of them needed shaving of anything. Weird.
ped
Post by ped »
Hi wheelman.
it looks like the cylinder head bolt holes are off a little. I wonder if it would restrict the transfers?
I was looking at my corsa to make a comparison.
Thanks, Ped. Off, how do you mean?
ped
Post by ped »
Wheelman-111 wrote:Greetings:
take a look at the photo with the dremel. you can see the bolt holes on the bottom. one side is closer to the transfer, the other one has more meat. the bottom holes look offset.
There may be blockage to the transfers? it won't sit centered on the block. :imo:
1man8scoots
Corsa vs contessa.
ped
Post by ped »
1man8scoots wrote:Corsa vs contessa.
ooh I see. good point 1man.
Wheelman, keep that dremel handy. :wink:
ped
Post by ped »
:peace:
1man8scoots
Block has not ever been decked or sanded down. This is a 350 mile engine that has never been opened up. Just like Johnny248 engine honda had some quality issues with these blocks.
