Case Half Sealing
Ben L.
Case Half Sealing
Post by Ben L. »
Hey I'm getting ready to install a new crank and bearings in my AF16.
I purchased Yamabond 5 to seal up the case halves. It is made for high temp usage but noticed the local motorsports store has Yamabond high temp also.
Can anybody tell me if you used the Yamabond 5 to seal your cases?
Thanks!
Johnniespeed
Re: Case Half Sealing
Post by Johnniespeed »
If your engine originally used a paper gasket for the case halves, and you remove the paper gasket, doesn't that put an undesirable side load on the crank bearings ?
Whatever the gasket thickness measured , say 0.020" , if you remove that gasket, aren't you side loading the bearings that amount ?
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
curtis966
Post by curtis966 »
Af16 does not use a paper gasket to start with. Af05 on the other hand does and they recommend you keep it that way and don't use liquid gasket in its place.
Yamabond and Hondabond might come from the same barrel-o'-goo at some Japanese petrochemical manufacturer. I really don't think it makes much difference which you use, but for $15 bucks a tube, why not go with the stuff Honda recommends?
1man8scoots
Post by 1man8scoots »
Yamabond 4 is what you want. Johnny248 had just did a big topic on it.
Yamabond 4 or hondabond ht.
Ben L.
Post by Ben L. »
Thank you. I actually found some hondabond from my last engine build. I'll use that since its holding up good.
