1994 Honda Elite S SA50 Build
paineisboss13
Post by paineisboss13 »
I'm building my '94 Honda elite s with the SA 50 motor. I want to use a 50mm bore kit i found on eBay. (http://m.ebay.com/itm/371320415883?nav=SEARCH)
What do you guys think would be the best carb and pipe I could get that won't compleatly drain my pockets.
Rip_City_Spree
Re: 1994 Honda Elite S SA50 Build
Post by Rip_City_Spree »
I love my polini carb and highly recommend them. You get what you pay for spend a little more for quality parts.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Some people have good luck with Taiwanese 50mm kits. Some don't. Improve the odds with careful inspection of every inch of the cylinder. Carefully chamfer the ports to avoid having sharp edges that reportedly shave all the oil off the piston. That huge Boost Port should in theory match the size of the block's port, but remember if you cut it out that big you've doomed the block to using cylinders with similarly-sized ports. That may eliminate the excellent Polini Corsa cylinder from eligibility, which would be a shame. If you have a bore gauge and the skills to measure, see how well the piston matches the cylinder. Often these are "bin-selected" and randomly too big or too small for each other. Like I said, you could luck out, but buying Italian takes a lot of the Luck out of it. For the price difference, it's worth it to me.
curtis966
Post by curtis966 »
^ All great advise. You get what you pay for.
The old scooter saying Graphie almost ( :) ) coughed up is:
Fast, Reliable, or Cheap: Pick any two. But in this case, with affordable Contesta or M'Arn kits, you can get fast and reliable FOR Cheap. My Flash 5 was a Taiwanese 50mm kit that I fussed over before bolting on, and it ran OK. Still runs, as far as I know. My experience with two other Tai 51s and a ministroker 90cc wasn't so good...
If this happens you have to split the cases, replace the bearings and start again. Now sometimes that's not so bad as it wasn't my Daily Driver and I enjoyed working on it, mostly, but you can burn out. Now it sounds like you've already bought the eBay kit, and I don't want to slag on you too much. But if you're willing to listen to advice from Those That Have Gone Before, you might consider re-selling it to the unsuspecting and switching tracks now.
Xxbeejay45xx
Post by Xxbeejay45xx »
Buy Italian you will save some money in the long run. Tried and true!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
