New Spree Build..AKA.."Little Evil"..125cc Hard Tail...
Hppowdercoatings
Post by Hppowdercoatings »
1984 Spree. Reinforced frame. Disc brake front end. 4.0" Stretch Engine Mount.
Rear Hard Tail shock mount... 125cc Bored/Stroked AF16
7:58 Gears..
Downsouthdio
Re: New Spree Build..AKA.."Little Evil"..125cc Hard Tail...
Post by Downsouthdio »
Awesome bike..and beautiful front end,good job,you better hold on tight lol :nervous:
Is that the motor that was on your elite e? Any top speed numbers?
Honda super dio
Corsa
26mm
Sparrow
Hppowdercoatings
Downsouthdio wrote:Awesome bike..and beautiful front end,good job,you better hold on tight lol :nervous:
Thanks.. Yes it's the motor out of my 87 elite.. No speed Numbers yet..
paulpauly7
Post by paulpauly7 »
Is it just the photos or are those front forks bent??
1man8scoots
Post by 1man8scoots »
paulpauly7 wrote:Is it just the photos or are those front forks bent??
That's how gy6 china forks look when there isn't a fender to make it look flusher.
Hppowdercoatings
That's part of it...lol but also because Forks/ Tripple tree just loosely bolted in, no bearings. Just for mock up. Have to take back apart to Powder coat..
patthesoundguy
Post by patthesoundguy »
That thing will certainly wake you up!I love it!
Hppowdercoatings
Took it apart last night and Sand blasted the frame, Handle bars, Controls. Today I Powder coated everything Satin Black..
1man8scoots
Looking good as always!
Hppowdercoatings
A little Progress.. Painted most of the Body panels Gloss black + clear... Have to wait till next weekend to wet sand and Buff out.. Got a Stock spree Seat & Seat Cover from EBay. Trimmed down the Seat Foam about 1".
Hppowdercoatings
Slowly coming together. Waiting on a couple parts. Have to order a shorter front brake hose. Custom Decals should be done this week.
kuromi
Post by kuromi »
Looks quick! You'll be needing that disc!
Would you be able to tell me what length the fork tube on the frame is and what, if any, mods you needed to do to the front end?
I've got a mini melody which I think might have a similar front end to the later spree.
Cheers!
1983 Melody Deluxe II / ND50MC
1984 Melody Mini / NP50D
1979 Simson Schwalbe KR51/1 (think 2 wheel trabant/ East German Honda Cub)
Hppowdercoatings
kuromi wrote:Looks quick! You'll be needing that disc!
Cheers!
Basically I used the forks,Brake caliper & Tripple tree off a TaoTao ATM 50 scooter. I removed the stem and welded in the Spree stem. I did take forks apart and cut the springs 2.0" to lower front end...
johnny248
Post by johnny248 »
* yeah that is sweet. What does the 125cc consist of as far as the jug and crank?
~UNDER CONSTRUCTiON~
Hppowdercoatings
johnny248 wrote:* yeah that is sweet. What does the 125cc consist of as far as the jug and crank?
54mm Bore
52.6mm Stroke...
