advanced timing
vette76
advanced timing
Post by vette76 »
does a spree have a key that holds the flywheel to the shaft? i found a special key for a pocket bike that advances the timing. is this a good idea?
check it out. here it is.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... eName=WDVW
vette76
Post by vette76 »
what is the purpose of the reed valve, and how does it work?
1) You could probably machine something to advance the timing on the Spree, but you would need to watch/listen for predetonation. You could blow a rod if it's not set up right. A dyno would be a good way to tune this.
2) Reed valves open when outside pressure exceeds inside pressure. This lets fuel in at the right time, just like intake valves on 4-strokes. Go to the MacDizzy site and look for info there.
vette76
Post by vette76 »
noiseguy wrote:1) You could probably machine something to advance the timing on the Spree, but you would need to watch/listen for predetonation. You could blow a rod if it's not set up right. A dyno would be a good way to tune this.
does a spree have a key like this and would it fit?
Not likely.
Tippmann98
Post by Tippmann98 »
That is a good idea for a mod. I may look into this
