stage 6 manifold
stage 6 manifold
Thinking about getting a stage 6 manifold. What do you guys think about it? Or is there a better one
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Stage 6 intake manifold
Sparrow Exhaust
Polini Ruckus Variator
Malossi Fly Clutch w/ blue
1500 contra
Lightened mag
7.4-1 gears
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
Re: stage 6 manifold
Haven't used the stage 6 but I really like my naraku. It has 2 different carb adaptors vs I think the 6 only had one.
1985 Spree AF16: viewtopic.php?f=20&t=31053
2001 Elite Daily: viewtopic.php?f=16&t=31397&p=272223#p272223
Which one allows the carb to sit the closest to the engine?
- cruzingratiot
Ben L. wrote:Which one allows the carb to sit the closest to the engine?
stage 6
you need to grind the boss for the float bowl to fit
Donate Life
http://www.donatelife.net/
Thank You
Thank You
that sucks that got to grind something to fit an intakecruzingratiot wrote:Ben L. wrote:Which one allows the carb to sit the closest to the engine?
stage 6
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
- Downsouthdio
1man8scoots
I haven't had to grind down any of the polini carbs yet when using the stage 6. Maybe the oko do but polini does not.
My PHBL25 was really close with the malossi mani but clears by far with the ct black.
