Honda Metropolitan (not sure what I will do with it) build
cruzingratiot
Post by cruzingratiot »
Well, I was made a offer I couldn't refuse on The POP build, so I sold it. viewtopic.php?f=16&t=31026
Always wanted a classic scooter, ( Cushman ),
but found a deal on a 2009 Metropolitan with 525 miles. (Original owner)
Since I got rid of the P.O.P and my Zuma,
they were the go to the store and leave outside mopeds (scooters),
so this one takes their place.
First thought, af16 2 stroke swap, (future plan ?),
but I have fun with the stocker for now.
As found, top pic, all red.
Then I vinyl wrapped flat pearl white and added white walls.
Stock 39mph.
More to come.
Donate Life
http://www.donatelife.net/
Thank You
MrJumps
Re: Honda Metropolitan not shure what i will do with it buil
Post by MrJumps »
put a lx 125, with the 188cc big bore
https://www.youtube.com/watch?v=g6FrkmWp4qQ
I wanna see a vespa motor with 4 gear on a spree... but this would break boundaries.
1man8scoots
Post by 1man8scoots »
The metro and minarelli swap is fast and fun. Those metros are light
cruzingratiot
Re: Honda Metropolitan (not sure what I will do with it) bui
Not much you can do to a GET 4 stroke engine
most people add a aftermarket ignition (more rpm)
take off the air box and change the variator
than carb intake
cam exhaust
no bolt on bb kit the block is the cylinder
not really much available in gearing
you can put stock metro secondary gears in a ruckus
(Primary: 12x42 secondary 12/47 ruckus) = 13.70 ? ratio 130 -90 10 tire
(Primary: 12x42 secondary13/45 metro) =12.12 ratio 90-90 10 tire
(Primary: 12x42 secondary13/45 af16 elite) =12.12 ratio 3.0 10 tire
kitaco KTC-305-1125210 primary gears ( I think 13-41) final ratio 10.90 ?
Ratio change:12x42= N3.500 (Stock) > 13-41=H3.150 (KITACO)
so the solution for gearing ?
af16 -18 and dio zx pulleys kymco zx50 ?
primary gears input 12t
tooth count same 12t
overall length same
dio undercut at gear end
spline end step different ( where the zx pulley clutch comes in)
primary gears input 42t
tooth count same 42t
thickness different but the secondary gear makes up for it
secondary shaft
clutch pulley assembly I used kymco zx50
so you can fit all the af16 elite gears in a GET metropolitan gearbox
than you can utilize all the gearing available for the elite af16
stock exhaust airbox cdi variator jetting gears
so with that said stock metropolitan 39 mph tucked
added polini variator stock weights 43,5
#72 to #75 jet intake restrictor removed
stock exhaust airbox cdi polini variator stock weights
trans swap 9.1:1 = 16x42 gears 2000 rpm clutch springs zx pulleys
47.5 mph tucked ran out of room
takes off better than stock more pull 30 to 40mph
biggest plus to gear change went 31 miles on a quart of gas that =120 mpg
more to come
intake restrictor on 2009 metropolitan
Donate Life
Thank You
1man8scoots
Holy cow my buddy just told me the block and cylinder is connected, wowza. There are people who bore them and do head work at the same time. Ive heard its expensive tho. In the end the only benefit to any tinkering is a few more mph. Get rid of the GET. Did you know stock compression is over 225. At 190 they are ready for a rebuild.
1man8scoots
I unfortunately see a lot of ruckus and metros every single day. Today was minimum 5 ruckus and metros.
ped
Post by ped »
Hi Cruz. Are you saying the AF 16 aftermarket secondary gears will fit the metro?
If so do we need to do any modifications?
Please let me know Thanks :rock:
Let me see if I got it
1. use AF16 or ZX clutch shaft?
2. Use AF16 secondary gear?
3. Use AF 16 final gear?
did I get it right? :confused:
cruzingratiot
ped wrote:Hi Cruz. Are you saying the AF 16 aftermarket secondary gears will fit the metro?
if you want to use the zx clutch and pulley and clutch bell assembly you change all 4 of the gears and shafts
if you want to use the stock clutch and pulley you keep the primary shaft for the clutch
((SHAFT, DRIVE (12T) 23411-GEE-710 ))
and replace everything else with the af16 gears
but I don't like the 2 shoe clutch and you need to change the clutch springs
to get the take off back
and than check the clearance on the secondary small gear you may need 2 steel washers
Donate Life
Thank You
Xxbeejay45xx
Post by Xxbeejay45xx »
Wow this is gonna be a nice thread about your metropolitans, lovin that two tone and white walls!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
ped
Post by ped »
Thank you
ped
Post by ped »
Thank you
