af16e on a sym dd50 frame?
- chamisataza
- Goped
i have a sym dd50 w/ honda elite (af16e)engine on it,the fuel pump on the sym dd have 2 hose 1 is for the carb and 1 is for the i think vacuum located at near the starter and oil pump there is a nipple but on the af16 engine there is no nipple or vaccum to put on now where do i put the other hose. pls help don't what to do.thanks
Re: af16e on a sym dd50 frame?
need to tap on lower ct chrome intake ( below reed valves ) for mod af16.
af16 oil pump shaft need to remove. use the brass as a vaccum and plug oil cap .
