malossi 47mm chrome bore block for dio 1,2 replacement pisto
xxgamerxx
Post by xxgamerxx »
Good day i have a malossi chromebore block for dio 1,2 but the piston is missing. I want to know if can i use a 47mm sheng e piston or any replacement piston set for this . Thanks
1man8scoots
Re: malossi 47mm chrome bore block for dio 1,2 replacement p
Post by 1man8scoots »
You have to use a bore gauge to measure your bore in 3 or more spots and I go with the largest readin g for the piston size I use. Make sure to measure the piston prior to install as well. May as well do a ring end gap measurement while you're at it.
