malossi 47mm chrome bore block for dio 1,2 replacement pisto
Posted: Mon Sep 07, 2015 3:02 pm
by xxgamerxx
Good day i have a malossi chromebore block for dio 1,2 but the piston is missing. I want to know if can i use a 47mm sheng e piston or any replacement piston set for this . Thanks
Re: malossi 47mm chrome bore block for dio 1,2 replacement p
Posted: Mon Sep 07, 2015 4:15 pm
by 1man8scoots
You have to use a bore gauge to measure your bore in 3 or more spots and I go with the largest readin g for the piston size I use. Make sure to measure the piston prior to install as well. May as well do a ring end gap measurement while you're at it.
