New Clutch Idea-Smart people welcome
deuce217
Post by deuce217 »
Hey I was sitting around thinking about how to make a clutch grab better. My idea is to create a clutch that has a cam-like movement that at a certain percent of movement relieves SOME spring tension from the "grabber" springs.
Key points:
The clutch arm travel will be held by the same springs as before but after the shoe moves past a particular fulcrum point the shoe then has less travel resistance allowing the shoe to grip harder without sacrificing low RPM grabbing.
I wish I had time to draw and upload a sketch on this. I wanted to share the idea before I forget.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
Re: New Clutch Idea-Smart people welcome
A picture is worth....yadda, yadda
but hey. I think you're actually on to something innovative... :surprise:
Interested in seeing what the engineers have to say about this. :urban:
cruzingratiot
Post by cruzingratiot »
deuce217 wrote:Hey I was sitting around thinking about how to make a clutch grab better. My idea is to create a clutch that has a cam-like movement that at a certain percent of movement relieves SOME spring tension from the "grabber" springs.
Key points:
you mean like the
dr pulley hit clutch
how the hit works
http://www.unionmaterial.com/images/HiT ... untion.png
main page for hit clutch info
http://www.unionmaterial.com/Hitclutch-19.htm
mine should be here thursday
Donate Life
http://www.donatelife.net/
Thank You
deuce217
Post by deuce217 »
Crushing riot,
Similar idea. I will have to look into that further. It sucks thinking about things that already have been made and produced!
50mm BBK (tai)
V-8 pipe
cruzingratiot
delivery came today
pics in link
viewtopic.php?f=20&t=27850&p=277685#p277685
Donate Life
Thank You
maddog
Post by maddog »
Check out the polini 2-G evolution clutch its the latest.
