Pulling a gear?
Ruckenstein
Pulling a gear?
Post by Ruckenstein »
I know this can't be right. Is there a smaller puller to get the variator side starter gear off an aero 80 to get to the seal?!
I tried all the positions on a 3 job puller. Any help would be great. If this goes smoothly I will personally make a how to video on this and post it to YouTube this winter. It will amass 9 hits a year. Lol
kuromi
Re: Pulling a gear?
Post by kuromi »
I keep a diary of everything I do.
I'll dig it out when I get home and see how I did it.
1983 Melody Deluxe II / ND50MC
1984 Melody Mini / NP50D
1979 Simson Schwalbe KR51/1 (think 2 wheel trabant/ East German Honda Cub)
Johnniespeed
Re: Pulling a gear?
Post by Johnniespeed »
You didnt say what year you have, usually helpful information, so I guessd a 1985. The puller that removes the starter gear is part number 07935-KG80000. Hope you have a friend at the local Honda Dealer who can smuggle it out for a night.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
kuromi
Re: Pulling a gear?
Post by kuromi »
Ok, so my diary says I used a gear puller.
It also says I pulled from the edge, not the slotted holes as the legs are too thick.
So my guess is that I either used a bearing puller or I managed to cram a three legged puller in there.
If it was a three legged puller, my smallest size is a 3" AmPro.
kuromi
Re: Pulling a gear?
Post by kuromi »
Also, if you've not tried it yet, tighten up the screw against the crank then give a sharp tap on the hex end with a heavy hammer before tightening a little further.
This often shocks the fit in to coming apart.
DISCLAIMER:
My Haynes manual says it's a very tight fit and if successful removal can't be guaranteed, take it to Honda
1man8scoots
Re: Pulling a gear?
Post by 1man8scoots »
Oh man crazy. I'm glad I haven't had to do that yet.
yamahauler660r
Re: Pulling a gear?
Post by yamahauler660r »
One of these pullers. I had to grind down the carriage bolt heads on one side. For my next one I am fabricating a 4 bolt steel plate puller adapter. With only the two bolts twisting sideways was a major problem I cut a 2x4 to fit between the ground and puller and stood on it. I used a piece of plywood to not crush the crank threads. I slightly heated up the gear too. Good luck, and watch your fingers!
(One of the carriage bolts stretched out and got tossed)
Last edited by yamahauler660r on Fri Oct 02, 2015 4:51 pm, edited 1 time in total.
My 2 wheeled bikes:
99 Elite S
97 Z50R
96 Elite S
89 Elite E x2
86/96 "Spree S/SpreElite"
87 Elite
86 Spree x4
86 Spree Special
85 Spree x3
84 Spree
83 Aero 80
80 XL250S
71 Trail 70 H
yamahauler660r
Re: Pulling a gear?
And as stated above, tap the puller bolt with a hammer
My 2 wheeled bikes:
99 Elite S
97 Z50R
96 Elite S
89 Elite E x2
87 Elite
86 Spree x4
86 Spree Special
85 Spree x3
84 Spree
83 Aero 80
80 XL250S
71 Trail 70 H
ped
Re: Pulling a gear?
Post by ped »
Hondahauler660r is right, lol. used carriage bolts. GL. :thumbwink:
