Engine Bogging
Hollandgriff
Engine Bogging
Post by Hollandgriff »
I have a 1986 honda spree nq50. It sat for 25years till last summer when i inherited it and got it running. I rode it as a daily driver to save on gas. Recently, ive been upgrading her. I got an upgraded spark plug, spark pug wire, and proformance cdi. Today i installed a 74cc big bore kit. It came with all necessary parts including a bigger jet. Whrn we got it running, the engine seemed to sound boggy. Before when this happened we just adjusted the gas. We tried that again but it still bogs. Along with the bogging, the speed took a dump. Just testing it out on the road, we only got to 20mph. We hope its just the break in, but open to any ideas
Re: Engine Bogging
It' not clear what you mean by "Boggy". How, exactly, did "we adjust the gas"? Just the air screw? How does the engine respond to throttle, exactly? Does it rev without power, four-stroke, or just stop firing and slow down?
Before "adjusting" anything else, I would recommend you pull the plastics and examine everything you've installed. Look for leaks, especially around the intake air box, filter, and that rubber mount to the carb mouth. Look for oil seeping around the various gaskets. Test your compression. Those blue CDIs often are not an "upgrade", despite their claims. I'd put the Honda module back in before going much farther.
Hollandgriff
Re: Engine Bogging
Thanks. I ended up checking the gaskets as you said. Upon further inspection, i saw that there was a leak in the cylinder. We put the gasket on wrong so gas was not getting into the cylinder.thanks for your help
Re: Engine Bogging
I am happy you found the cause. Did you generously grease the gasket before installing the cylinder? If so there is a chance of re-use. If not Taz may have replacements.
Ultraliner
Re: Engine Bogging
Post by Ultraliner »
A74cc big bore kit for a spree? Where did you get this from?!
Re: Engine Bogging
Ultraliner wrote:A74cc big bore kit for a spree? Where did you get this from?!
Board member "tazland001" also sells on ebay with the username "chop-chop123"...Spree big-bore kits.
