strange noise after drop
Posted: Sat Oct 10, 2015 10:39 pm
by impalo
My son dropped my 2001 Elite SA50 at a standstill on the kickstart side. Bike was running. The kickstart then proceeded to go down on its own with some cluncking noise and deep grinding. I shut it down.
On trying to restart with starter the kickstart will go down again. I would then have to pull the kickstart back up. i repeated this a couple times. I tried to kickstart and same luck there.
I took the kickstart cover off and see nothing wrong, to my eye. ?
I am a new scooter owner. Someone please Help!
Re: strange noise after drop
Posted: Sun Oct 11, 2015 1:42 pm
by impalo
graphite9 wrote:If you pull the kicker lever off, there is a c clip that keeps the kicker lever tight in the cover. If the clip gets damaged, it will allow the mushroom gear to go more inwards towards the drive face. Most likely that clip was damaged. Should be a cheap fix! I bet there is someone on here with one they could send you. Lots of good guys on here.
That tiny little clip keeps the kickstart in place? WoW!
This worked!! Thank you very much.
