ruckus front wheel on an aero50?
Posted: Fri Oct 23, 2015 11:16 pm
by benji
Will a ruckus front wheel fit on my 86 aero? And how about the brake panel? I hear that a met front wheel will work and so will an elite wheel, also heard that an elite front brake panel and the met front brake panel works. Any body know for sure? I've measured my forks and it's a Lil over 3.5" in the middle where it bolts up, and that seems to be the skinniest place the rim would have to fit through to bolt on.
Re: ruckus front wheel on an aero50?
Posted: Fri Oct 23, 2015 11:18 pm
by benji
I'm trying to figure out if the ruckus setup will work cuz one of the guys on here has the wheel and brake for cheap
Posted: Sat Nov 07, 2015 2:47 am
by superfast1234
If the tire clears the fender you may have to cut the spacer, if you need 5 way adjustable shocks I can get them $100
