Clutch Question
gnrphantom
Clutch Question
Does anyone know if a clutch outer / clutch / driven pulley from an 86 Spree will work on an 84 or 85? I am not sure if they were the same throughout the four year run of the spree. Nothing is noted in my shop manual. I am seeing that the drive pulleys are different, so I am just wondering. Any insight would be greatly appreciated.
Re: Clutch Question
Online vendors make the parts fiches available online. You can check part numbers. That said, I would be surprised if the years don't interchange.
Re: Clutch Question
Looks like the clutch end uses the same part numbers 84 and 86. The drive face is different part number but uses same belt, so should interchange.
gnrphantom
Re: Clutch Question
I want to thank you guys for your responses. It is greatly appreciated!
Re: Clutch Question
I've had just a whole bunch of Sprees and the clutch is one of many parts that will fit all years. Ya just can't ride a Spree without smiling.
