issues with my Prebug build
Downsouthdio
Re: issues with my Prebug build
Post by Downsouthdio »
You still have it grounded at the factory location?change it if you do..and if you can just drop a smaller carb to see how she reacts
Honda super dio
Corsa
26mm
Sparrow
veedubh20
Post by veedubh20 »
I love sound pop n back fire.
benji
Post by benji »
G9, I'm not sure about specific problems w ground on the zumas, buy these bikes in general seem to have ground issues. On my bike I've noticed everything has a ground wire run to the batt and split off instead of grounding the frame. I've been slowly changing it over one by one, and it seems to be a magic spell that fixes stuff-starter works great, turn signals flash quick and bright, headlight worked better, etc. The way I do it is running a wire from batt straight to the frame (clean the paint from contact point), then find every ground split in the harness and replace it w a ring terminal and ground it to the frame.
1man8scoots
Post by 1man8scoots »
Just too much carb for the bore. Same with any sub 82cc, 24mm is all you will ever need.
veedubh20
Post by veedubh20 »
tuning vary on 24 vs 28mm carb... 28mm is better.
