87 elite with 94 motor??
808se50
Post by 808se50 »
So since there's not too many upgrades for my afo5e im just gonna do a swap on it but before I do...
Would a AF16 motor mount on to my 87 elite se50 frame and will the harness from my af05e be compatible with the af16? What about the wheel tooth is it any different from the afo5e to the af16?
veedubh20
Re: 87 elite with 94 motor??
Post by veedubh20 »
you will need to change motor bushings on af16 block.
metro rim or s rim fit on af16 main axle shaft
yes the wiring color is same af16 to se50 wiring. need to cut, spice, get a motorcycle connection hold 6 wires.
