need help with carb
zoom
need help with carb
Post by zoom »
i took the carb off and cleaned it.. and now since ive put it back on it floods with gas gas shoots out of the float bowl on the side.. so i took it off and i think i put a part in backwards so i switched that and then it was running perfectly but i let it idle and it flooded with gas bad.. what do yall think the problem is. any information would be good because im new to this.
vette76
Post by vette76 »
do you have an air filter? if you do not have an airfilter installed you NEED it. it seems weird but that type of carb needs an air filter to work and run properly and faster.
87' spree (SOLD
12' wrx
zoom
Post by zoom »
yea
vette76
Post by vette76 »
there should be a screw at the very bottom of the bowl. is it screwed in all the way. you also said you cleaned the carb, did you also clean the gaskets with carb cleaner? because carb cleaner will destroy rubber gaskets.
87' spree (SOLD
12' wrx
zoom
Post by zoom »
no. but when u take the float off there is a little needle that is kjinda at the base of the float and is that all of the needles out of the bottom besides the jet.
vette76
Post by vette76 »
yeah, that regulates how much fuel enters the carb so make sure all that is free moving.
87' spree (SOLD
12' wrx
zoom
Post by zoom »
how tight should i tighten the float or should i leave it free m,oving.
zoom
Post by zoom »
mikehailwood
Post by mikehailwood »
The float should be loose and free to "float" up in the fuel until the bowl is full and the needle seats and shuts off any additional fuel from flowing into the bowl. (bad sentence, reply if it makes no sense)
zoom
Post by zoom »
that little needle i guess its the fuel shutuff needle its under the float. wen i put it in with the pointy side in the hoil it runs fun until i let it idle but slso the pin that holds the flaot is loose wen the flaot is loos and i was just wondernin will that fall out when its loose.
mikehailwood
After you slide the pin onto the float you install the float, inserting the pin into position in the groove. Then you install the short screw which holds the pin in place. The pin should be fixed in position held tightly by the head of the screw. The float should pivot freely on the pin.
zoom
Post by zoom »
hmm. thats my problem. i was wondering which way does the fuel shutoff needle go in?
vette76
Post by vette76 »
the pointed part in the hole first so the end fits in the slot of the float.
87' spree (SOLD
12' wrx
zoom
Post by zoom »
now every thing in carb is put back togethor right it wont crank.. it will start to sputter but wont crank or stya cranked. im gonna try the spark plug. but what do yall think
zoom
Post by zoom »
