Stripped mounting bolt
- Apollo_Fluff
Well I've figured out engine removal but the engine mounting bolt is stripped, help
Re: Stripped mounting bolt
What do you need "help" with ?Apollo_Fluff wrote:Well I've figured out engine removal but the engine mounting bolt is stripped, help
You've already got the engine out.
Did you forget how to put it back ?
Johnniespeed
Turn and turn but it doesn't come out ? Put a wrench on the nut on the other end of the bolt.
Turn and turn but it wont tighten ? Post a pic of the threads, could need a heli coil insert.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
Are you talking about the large main bolt and nut that connects the engine to the swingarm thing? If it's stripped-stripped, that sounds weird. But if it was me, I would have already either cut the nut or bolt by now with a die grinder and cut off wheel. It's easy enough to just replace that.
~UNDER CONSTRUCTiON~
