Elite stem loose
given123
Elite stem loose
Post by given123 »
My elite s has a disk front set up with the elite s stem and ZX triple tree
The problem is it's been about 4 months since I got the stem out on and now after maybe every couple days after riding the handle bars get loose so I have to tighten the nuts. What's the problem ?
Honda Elite SR 1996 AF16e Polini Contessa Ported 28oko Arrow pipe
Honda Aero 50 1987 AF05 Malossi Big Bore Kit 14 Kehin Oem Honda Pipe
kuromi
Re: Elite stem loose
Post by kuromi »
Are you using Loctite or similar thread locker to lock the threads?
1983 Melody Deluxe II / ND50MC
1984 Melody Mini / NP50D
1979 Simson Schwalbe KR51/1 (think 2 wheel trabant/ East German Honda Cub)
given123
Post by given123 »
Oh no I don't I just tighten both the large but and smaller but as tight as I can but it still gets loose. So i should apply loctite on the threading of the stem ? and which loctite do i use ?
kuromi
Post by kuromi »
I use Loctite 243 - medium strength. Comes as a blue liquid in a red bottle (some people call it the "the blue one")
It stops stuff vibrating loose and you can still undo the fastenings using hand tools.
Stronger Loctite is available but needs heat to break the bond.
1man8scoots
Post by 1man8scoots »
Blue loctite. But you shouldn't be having to do this. Tighten the bottom nut to 16 NM and top to 35 NM and you won't have any issues.
