Looking for new airbox!
sffalcon
Post by sffalcon »
Greetings :hi:
I have a 1988 Honda Elite LX. My stock airbox is having issues sealing properly around the mouth of the carb causing poor performance.
Im looking at Babbits for a replacement. They don't have a 1988 air cleaner housing, but they do have one for a 2001 elite 50.
Will the 2001 Air cleaner housing work on my 88?
Thanks!
1988
xXsHrEdXx
Re: Looking for new airbox!
The 1988 Elite LX has the "AF05E" engine.
The 2001 has the "AF16E".
Expect exact fit to be unlikely.
Some of our more experienced members will have
the answer you need. [Will it or won't it work?]
Good luck... :urban:
bonesv
Post by bonesv »
YES!.......they are the same carburetor(basically). It will work, it's the same size, but there is a small space(length)difference on the rubber connector with the clamp. Just push it up a little closer together with the carburetor so the air box mounting bolts will line up. It's easy to fit.
I have a bunch of these old, dried out rubber connectors in sa50 air boxes just waiting for someone to make them work again! but, wait!
............I am in the process of re-fitting them with new, larger(honda made part)rubber connectors for anyone with say, a jdm sk50 dio carburetor? or a aero nh80-sized carburetor? and want to keep the sa50 air box.
I will be posting them very soon here on hs.net.......
kevinv710
Post by kevinv710 »
i do have both Airbox 2001 and 1988 LX, they are not the same. If you need 1988 LX let me know.
bonesv
Post by bonesv »
Now I have to go check in my storage......
It's been years since I had the stock motor in my lx but I can remember the rubber getting so dried out and hard it would not stay on the carburetor so I used one from my used elite sr parts. I thought it fit good enough. I was not saying they were identical. I know the covers swap too and uses the same filter.
