Digital speedometer and fuel gauge
solid808
Post by solid808 »
Ok guys I have a sym dd50 and would like to replace the speedo gauge to something like the vapor gauge. But want everything to be custom mounted in where the stock speedo cluster is. But my thing is the vapor gauge doesnt have a fuel gauge. Which speedo do you recommend to run with fuel gauge in it? Or run the trail tech vapor somehow with a fuel gauge next to it? Anybody got any ideas or have done it already? Pictures and advise would be greatly appreciate it.
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Stage 6 intake manifold
Sparrow Exhaust
Polini Ruckus Variator
Malossi Fly Clutch w/ blue
1500 contra
Lightened mag
7.4-1 gears
solid808
Re: Digital speedometer and fuel gauge
Post by solid808 »
solid808 wrote:Ok guys I have a sym dd50 and would like to replace the speedo gauge to something like the vapor gauge. But want everything to be custom mounted in where the stock speedo cluster is. But my thing is the vapor gauge doesnt have a fuel gauge. Which speedo do you recommend to run with fuel gauge in it? Or run the trail tech vapor somehow with a fuel gauge next to it? Anybody got any ideas or have done it already? Pictures and advise would be greatly appreciate it.
Hmm anybody?
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
MrJumps
Post by MrJumps »
Run the trail tech and get a external fuel gauge unless you want to spend 500 or so on a custom face board and gauges
solid808
Post by solid808 »
graphite9 wrote:I could go on for days with koso and stage6 gauges. All 1 week order because i don't get too many requests.
speedometer: 0 - 360 km/h (225mph)
odometer: 99,999.99 km
run time: 999.9h
tachometer: 0 - 15,000rpm
gear shift signal
engine temperature: 0 - 250┬░C (32 - 482┬░F)
fuel gauge
clock
voltmeter
lights: headlight, indicators, neutral, oil, gear shift
dimensions: 120x68.5x44.1mm
Weight: 127.3g
power supply: 12V DC
how much do they run?
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
solid808
Post by solid808 »
graphite9 wrote:$175-200. Trailtech is $125 or so. i have three TT kits coming in, but no fuel of course. I do have peel and stick stage6 fuel gauges, backlit.
how does that stage 6 peel and stick gauge look like?
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
solid808
Post by solid808 »
so getting the trail tech and the gauge comes to about the same amount as the koso? which one would you prefer
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
MrJumps
Post by MrJumps »
run time: 999.9h
gear shift signal
fuel gauge
clock
voltmeter
Weight: 127.3g
That secound one looks sexy as *. Like a old style honda hornet would rock one of those. Can I have a link to that one in particular. Im gonna add it to my save up for list.
solid808
Post by solid808 »
graphite9 wrote:Those are the big baller kits, There are some lesser ones. I just put up the TT kits. Grab stuff today or tomorrow, enter coupon code christmas to get 15% off everything.
ordered... thanks again
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
1man8scoots
Post by 1man8scoots »
I love my s6 gauges so far. I still haven't installed the fuel meter yet because I'm not sure which bike to use it on really. I need to order another one so I can just use the one I have and worry later. Nice selection there!
solid808
Post by solid808 »
how did you guys mount the speed sensor on the vapor?
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
bonesv
Post by bonesv »
solid808 wrote:how did you guys mount the speed sensor on the vapor?
It depends on which unit you have. Did you get the kit for a yamaha blaster? That one has the 14mm spark plug temp sender but the speed sensor is tricky and it is easier(imo)to mount it at the rear wheel using the curved bracket such as trafficjamz did a few years ago. Here it is just so you won't have to waste time using the search feature...........viewtopic.php?f=4&t=21036&hilit=+speedometer+sensor
solid808
Post by solid808 »
graphite9 wrote:nice job! Yeah its a little tricky, you need to get creative for sure.
Thanks again
Didn't like this came out on the cutting need to do again... but enough to go riding for now
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
solid808
Post by solid808 »
got to redo the cut outs for it not satisfied with it. The NCY shocks ride so much better then those RRGS. Now got to save money for NCY calipers, bracket, and new Rotor lol
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
bonesv
Post by bonesv »
Very nice indeed! Where did you get the adapter for the caliper? I need one, lmk!
solid808
Post by solid808 »
bonesv wrote:Very nice indeed! Where did you get the adapter for the caliper? I need one, lmk!
It came with the kit graphite sold me.. just had to cut
2006 SYM DD50
72 Corsa
Mini Stroked
26mm Polini carb
Sparrow Exhaust
1500 contra
Lightened mag
7.4-1 gears
