Not enough compression?
indy111
Post by indy111 »
Can someone please give me some insight on this issue I'm having.
I have an 86 Spree with low compression 30lbs. It would not start. I pulled the cylinder to find a broken piston, scored cylinder wall and what looks like a base gasket leak. There is plenty of oil and greasy grime everywhere.
I had an extra, used piston, rings and cylinder, all from extra parts box. Everything looked clean and fit really goid together, I thought they fit like a glove. I put brand new top and bottom gaskets on the head and cylinder. Once it was all back together it barely started and my compression only went up to 40lbs.
Do I need to look for a crack in block or something else.
I put 7lbs torque on the head bolts.
Thanks for any help.
1man8scoots
Re: Not enough compression?
Post by 1man8scoots »
Torque those head bolts to 10 lbs and retry. I know book says less but 10 is safe and sure to seal.
Cracks will show up as dirty lines wherever they are. Seals at the crank ends need to be sound. Reeds must be installed but the carb removed or held wide-open while you crank up compression. Add a few drops of 2-stroke oil and re-test. If compression goes up significantly, the ring fit in the cylinder isn't right.
1man8scoots
Solid advice!
indy111
Post by indy111 »
Ok, thanks for all the advice. I'll let you all know what happens.
