Kymco Agility 50 derestriction
Wondering if Kymco Agility 50 has a washer in the variator that can be removed ?
Are there any other items that are intended to restrict this bikes' top speed ?
Starting the research now, just picked it up last night...6k miles...2010 model.
tia...mm... :urban:
Re: Kymco Agility 50 derestriction
* File photo
Kymco agility_50_red.jpg (12.67 KiB) Viewed 44493 times
MrJumps
Post by MrJumps »
If I rember corectly those scooters come with a chinabay type rev limited cdi. Also the carb lrobably has a restrictor for Ca law requirments.
MrJumps wrote:If I rember corectly those scooters come with a chinabay type rev limited cdi. Ah...I have no knowledge of this CDI...will keep this in mind...have not had warm enough day today to get a good idea of just how well it rides....runs and idles very good on the stand.
Also the carb lrobably has a restrictor for Ca law requirments.Is this referring to the limiter on the idle-air mixture screw ?
kevinv710
Post by kevinv710 »
Hi Mike,
that washer can be flat down or replace it with unrestricted one, Kymco 50cc restrictions depend on models, years, States. Generally, most restriction items are: washer boss(most), CDI(not all), muffler(most). The best way to find out what yours is to call Kymco with your scooter VIN#, they will tell you about. My People 50 S 4T had only washer and muffler need to be unrestricted, so i did replace that washer and leave muffler alone, i got 5-7mph extra with that, max out 35-40 mph flat ground. Nice looking bike Mike!
MrJumps
Post by MrJumps »
Sometimes the carbs have a flange rubber like neck in it that keeps air and fule flow low at high vacumme. You just pop it out and up jet and gain 3-5 mph
1man8scoots
Post by 1man8scoots »
Agility have a cdi restriction and variator ring. I doubt at 6k it still has the variator restriction but probably has the cdi restriction. You have to cut the cdi with a hack saw blade perfectly. Kymco forums has a sticky on it I bet. They are dc cdis so you have to remember that if you order an after market one.
Kevin you have a people 50 4t? I've yet to see one but we get the agility and super 8 50 4t in pretty often. At least you have the bigger rims to help with top speed.
MrJumps
Post by MrJumps »
I dont even know why the goverment bothers with restricting these scooters... everone just unrestricts them anyway. Also I found out that some have a small washer in the pipe that restricts it too. Also since its at 6k miles check valve clearence it may be running ok but those 4ts are little sneaky boogers.
Thanks to all who have replied... :hi:
This scooter has been sold to a close friend,
and I have told him of these items to check for possible restrictions... :urban:
kevinv710
Post by kevinv710 »
i do know this post is over since Mike has sold his scooter, but i feel i still owe my pal Mr. 1man8scoots a picture of what i have, so please forgive me, if you might see it as a non sense reply. Have a good one, Everyone!!!
1man8scoots wrote:Kevin you have a people 50 4t? I've yet to see one but we get the agility and super 8 50 4t in pretty often. At least you have the bigger rims to help with top speed.
Yes, 1man, i do have one, i like the look of it, the wheel and the comfort too.Image
This thread is 3 1/2 years dead.
